Home > Forums > ANSYS Meshing & Geometry
[ICEM] 2D Mesh of a Venturi : Errors during importation under FLUENT_v6
Old   February 7, 2011, 17:33
Default 2D Mesh of a Venturi : Errors during importation under FLUENT_v6
Thibault
eeesprit is on a distinguished road
NB - Sorry for the english mistakes that would certainly follow...
First of all, good evening !
I'm working on a project, which aim is to study the possibility or not to cool the fuel cell of my school's car prototype, using the depression created by a Venturi which would be integrated on the structure of the vehicle.
The thermic part is over - now i wanna to see the impacts on the car's aerodynamics, especially drag coefficient Cd.
I started with very simple shapes : cylinder in an air flow - i am satisfied with the results which are very close to the theory.
Before trying to mesh complex shapes (i.e. the shape of the car) i would like to try with this :
a Venturi inluded in a Sphere (see the attached picture)
Because i'm beginner with ICEM & Fluent, i don't know how to mesh such a situation. Indeed, there are some "isolated walls" just in the middle of our an air flow.
Anyway, i tried to do something like that :
- definiting 3 surfaces for the Fluid (air)
- meshing these surfaces (i tried both TRI & HEXA unsuccessfully)
- setting boundary conditions
(by the way... what's the appropriate boundary condition for separation between my "fluid" surfaces ? interior ? interface ? thanks)
BUT
when i try to read the mesh with Fluent :
Warning: Invalid face type 1. Skipping
Warning: cell 0 of thread 46 has NULL face pointer 2.
Clearing partially read
Error: Build Grid: Aborted due to critical error.
I read some posts on this forum with users who had the same problem : it was often related to "Uncovered Faces".
But i check the mesh, and there aren't any "Uncovered Faces".
Any ideas where the problem could come from ??
Thank you very much.
Thibault
eeesprit is offline   Reply With Quote
Old   February 8, 2011, 14:12
Retired from CFD Online
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
If this is a 2D model, how did you model the 4 regions? Are they separate parts (zones)? Do you have line elements between the zones (check this by turning on all parts, turn off shells, turn on lines... Do you see line elements between all the zones?
You should, other wise fluent can't keep the fluids apart.
Why do you even have 3 fluid regions? Can you put them all in the same part/zone? Then you wouldn't need line elements between them.
PSYMN is offline   Reply With Quote
Old   February 9, 2011, 12:20
Thibault
Thanks for your answer, PSYMN
Yes i think i did this correctly ; indeed i have 3 surfaces, separated by lines.
Actually, because i'm not used to ICEM, i thought it was the easiest way to do for me.
If i don't make these separated zones, how can i mesh the volume properly without taking in consideration the "wall elements" (i.e. the sphere) ?
That was a kind of "tip" to mesh the volume part after part, but maybe this is the reason of the errors under Fluent...
Basically, what are the main steps i need to do to mesh such a structure ?
Thanks,
Good evening
Thibault
Old   February 9, 2011, 14:13
PSYMN's Avatar
Simon Pereira
What mesher are you using? Hexa? Patch Conforming quad?
Old   February 9, 2011, 14:15
Thibault
Interesting....
Instead of setting 3 different surfaces with 3 names (SURF1, SURF2 & SURF3) i try to set only one name : SURF.
Then, i mesh the 3 surfaces (corresponding to one part only) together, and after creating a file.msh, i have a new error :
Error : FLUENT received a fatal signal (SEGMENTATION VIOLATION)
That's still doesn't work, but i'm going on ...
There are some other topics relating this error, certainly caused by a lack of memory ...
what should i do to avoid this error ?
Old   February 9, 2011, 14:16
Thibault
That's it : Patch Conforming Quad !
Thread Tools
Trackbacks are On
[ICEM] Negative volume error in hybrid mesh siw ANSYS Meshing & Geometry 4 September 3, 2014 05:25
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
external flow with snappyHexMesh chelvistero OpenFOAM 11 January 15, 2010 20:43
Mesh errors in small faces Mark Arinov FLUENT 0 June 3, 2006 18:13
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 11:09
