[ICEM] Nodes on sides of the edges don't match
Old   February 9, 2011, 08:25
Question Nodes on sides of the edges don't match
Attesz's Avatar
Attesz
Attesz is an unknown quantity at this point
Hi ICEM users,
i've a problem related do 2D mapped hexa meshing. There is an edge, where the nodes don't match. There are no multiple edges on each other, I've checked it. The vertices, edges are well associated to points and curves. But the nodes as you see on the pic, don't match. Do you have any suggestion excluded the fully rebuild of the model?
Thank you in advance,
Attila
Attesz is offline   Reply With Quote
Old   February 10, 2011, 20:20
Default A single edge can't have 2 distributions.
PSYMN's Avatar
Simon Pereira
This doesn't seem right... A single edge can't have two distributions. Therefore that can't be a single edge.
Try a couple more things in the display tree to diagnose the problem.
Right click on Verticies and turn on "Numbers", this will make it easier to see overlaps because you will see overlapping numbers at the vertex.
Right click on Edges and turn on color by count. edges that connect two blocks should show up red. Yellow edges indicate a disconnect.
associate, edges, hexa, icem, nodes match
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
gmsh2ToFoam sarajags_89 OpenFOAM 0 November 24, 2009 22:50
Displaying only edges and not nodes of the grid in contour views val3312 FLUENT 1 May 26, 2009 02:27
