Home > Forums > ANSYS Meshing & Geometry
shadding vortex
Old   February 9, 2011, 12:48
Default shadding vortex
Lombo is on a distinguished road
Hi!
i'm a cfd newbie and i'm trying to solve a tipical cfd problem: catching shedding vortex (shown in the figure below) generated by a steady flow around a circle (2D) with Fluent
i'm trying to solve it with a k-eps model (unsteady analisys). for the mesh i use a boundary layer around the circle and a triangular growing size mesh all over, (more thick in the tail) is this correct?
and about the wall condition, do i have to use one?
thank you very much!
Lombo is offline   Reply With Quote
Old   February 10, 2011, 03:01
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
here one example for laminar flow:
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   February 11, 2011, 06:51
thanks, but is not i was looking for....
now i undertstand that i can obtain the phenomenou by chosing a different viscous turbolence model according to the reynolds number...
is it correct?
thanks
Old   February 11, 2011, 07:05
-mAx-'s Avatar
Maxime Perelli
I answered to this question
is it correct?
No the phenomenon doesn't depend on the turbulence model, but on the Reynolds number
Old   February 11, 2011, 11:56
yes! thank you very much!
i resolved the case with k-eps model, and now i'm trying to change their values (k and eps) to understand how they affect the phenomenou...
but i don't really understand...
moreover i would know how to choose this parameters
Old   February 11, 2011, 12:25
-mAx-'s Avatar
Maxime Perelli
k and eps are fixed (you impose a specific turbulent flowfield given by Re >> check litterature)
So you are not supposed to change their values as you are not supposed to change the inlet velocity (for a given Re)
Old   February 11, 2011, 12:51
i use fluent and with this software i have to specify the velocity at the inlet, k and eps (how choose them?)... i calculate the reynolds manually..
Old   February 14, 2011, 02:31
-mAx-'s Avatar
Maxime Perelli
there are formulas for k and eps.
Check online help chapter 7.2.2 "Determining Turbulence Parameters"
Old   February 15, 2011, 11:42
what is the different between the steady and unsteady command?
i tried to solve a simple 2-d problem of a beam section:
with the steady solution a k-eps viscous model sometimes i cath the oscillation of the lift coefficient, but with the unsteady k-eps i don't reach the same results...
i don't understand why this happens, because in general the flow should be unsteady....
Old   February 16, 2011, 03:02
-mAx-'s Avatar
Maxime Perelli
If you get oscillations with a steady solver, then the oscillations are due to the convergence. Understand you solution is moving untill it reaches its converged value (if your model has a steady solution)
In unsteady solver, the oscillations are unsteady oscillations with respect of time (and not iterations as in steady solver)
Old   March 3, 2011, 04:52
Ugly Kid Joe
vmlxb6 is on a distinguished road
Why are you trying a steady state solution ??????? Flow over a cylinder is not a steady state problem............ It is a transient case problem.
vmlxb6 is offline   Reply With Quote
Thread Tools
Trackbacks are On
creating vortex core line aay023 Main CFD Forum 0 September 15, 2010 21:49
Air-Jet Vortex Generator, request for some papers ROOZBEH FLUENT 0 July 12, 2008 10:28
Air-Jet Vortex Generator, request for some papers ROOZBEH Main CFD Forum 0 July 12, 2008 10:27
turbulent scales of forced vortex and free vortex lcw Main CFD Forum 3 September 1, 2005 13:40
Free vortex - forced vortex Armin Hofstädter Main CFD Forum 2 November 17, 1998 19:55
