Home > Forums > ANSYS Meshing & Geometry
Distribution of face mesh
Old   February 10, 2011, 19:03
Default Distribution of face mesh
kostas
pankos is on a distinguished road
For face meshing it must be,first, determined the nodes of all its edges. If i want to determine additional nodes for different distribution of face mesh must be on face edge or on other edge type?
With other words, i must "split" the face at location where i want to add nodes so that to appear edge?
pankos is offline   Reply With Quote
Old   February 11, 2011, 02:22
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
Not necessarly, you can mesh the surface directly. Gambit will mesh the edges with the size you gave in the surface mesh panel
Yes. Split your surface. you will introduce new topology (edge-point or surface) which can be used as source in a size fonction
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   February 11, 2011, 04:07
kostas
Ok.Thanks. But after meshing can i delete all these inner topologies so that ramain only the mesh? I want this i order to use this mesh face as sourse face in "cooper algorithm" for 3d meshing but if sourse face has inner topologies connot work.
Old   February 11, 2011, 04:40
-mAx-'s Avatar
Maxime Perelli
if you split your surface into 2 surfaces, than take the 2 surfaces as source for cooper
Old   February 11, 2011, 06:55
kostas
Yes but if split partially the face (hard edge), i have not 2 faces. I have again 1 face with inner edge which can connect or not with outer edges.
Is there any way from this?
Have you man to talk more easy?
Old   February 11, 2011, 07:11
-mAx-'s Avatar
Maxime Perelli
hard edges are supposed to be fixed....
But you can try.
Why don't you want to split your face into 2 surfaces?
I don't understand what you mean
Old   February 11, 2011, 07:56
kostas
xaxa sory. I mean msn.
Have you msn to talk more easy?
Old   February 11, 2011, 07:59
-mAx-'s Avatar
Maxime Perelli
no msn
did you try to mesh your surface with an hard edge?
Old   February 11, 2011, 08:04
kostas
Yes, the mesh of face is ok. Near hard edge i have dense mesh as i want. But i can not use this face for cooper alg. due to hard edge. Can i have the same mesh of face in face without hard edges(splits)?
Old   February 11, 2011, 08:18
-mAx-'s Avatar
Maxime Perelli
yes it failed because of hard edge.. that's why you need to fix it.
Tell me why you don't want to split your surface into 2 surfaces?
Old   February 11, 2011, 08:50
kostas
Because, i want to distibute nodes at specified length of edge.
Look. I have make a NACA airfoil and i want to run it in transonic regime. I must put, general, few elements (less computational cost) but in region where appear the shock i want dense mesh. Therefore, i need dense mesh only near of hard edge. In residual face the pave method must do its work.
Ok. finally i will do as you talk(split at two faces) but i believe that there is a way to disconnect mesh by topology so that to move only mesh in same face without hard edges. Is there?
Old   February 11, 2011, 08:55
-mAx-'s Avatar
Maxime Perelli
can you post a picture of your model naca?
Old   February 11, 2011, 09:00
kostas
This is the 2d mesh. The hard edge is appear in above face.
Old   February 11, 2011, 09:17
-mAx-'s Avatar
Maxime Perelli
Then split your surfaces so that your "shock-line" divide a surface into 2 surfaces.
For example like that
Old   February 11, 2011, 09:35
kostas
Ok. Thanks. I will do with this way.
Old   February 11, 2011, 13:41
kostas
Finally, it is working! The cooper scheme work with this way. Look the picture in witch i have split the face in three sub faces.
Thread Tools
Trackbacks are On
SnappyHexMesh for internal Flow vishwa OpenFOAM Native Meshers: snappyHexMesh and Others 24 June 27, 2016 08:54
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
BlockMesh FOAM warning gaottino OpenFOAM Native Meshers: blockMesh 7 July 19, 2010 14:11
external flow with snappyHexMesh chelvistero OpenFOAM 11 January 15, 2010 20:43
BlockMeshmergePatchPairs hjasak OpenFOAM Native Meshers: blockMesh 11 August 15, 2008 07:36
