February 10, 2011, 18:03 |
Distribution of face mesh
kostas
For face meshing it must be,first, determined the nodes of all its edges. If i want to determine additional nodes for different distribution of face mesh must be on face edge or on other edge type?
With other words, i must "split" the face at location where i want to add nodes so that to appear edge? |
February 11, 2011, 01:22 |
#2 | |
Maxime Perelli
Rep Power: 41 |
Yes. Split your surface. you will introduce new topology (edge-point or surface) which can be used as source in a size fonction
In memory of my friend Hervé: CFD engineer & freerider |
February 11, 2011, 03:07 |
kostas
Ok.Thanks. But after meshing can i delete all these inner topologies so that ramain only the mesh? I want this i order to use this mesh face as sourse face in "cooper algorithm" for 3d meshing but if sourse face has inner topologies connot work.
February 11, 2011, 03:40 |
Maxime Perelli
Rep Power: 41 |
if you split your surface into 2 surfaces, than take the 2 surfaces as source for cooper
February 11, 2011, 05:55 |
kostas
Yes but if split partially the face (hard edge), i have not 2 faces. I have again 1 face with inner edge which can connect or not with outer edges.
Is there any way from this? Have you man to talk more easy? |
February 11, 2011, 06:11 |
Maxime Perelli
Rep Power: 41 |
hard edges are supposed to be fixed....
But you can try. Why don't you want to split your face into 2 surfaces? I don't understand what you mean
February 11, 2011, 06:56 |
kostas
xaxa sory. I mean msn.
Have you msn to talk more easy? |
February 11, 2011, 06:59 |
Maxime Perelli
Rep Power: 41 |
no msn
did you try to mesh your surface with an hard edge?
February 11, 2011, 07:04 |
kostas
Yes, the mesh of face is ok. Near hard edge i have dense mesh as i want. But i can not use this face for cooper alg. due to hard edge. Can i have the same mesh of face in face without hard edges(splits)?
February 11, 2011, 07:18 |
Maxime Perelli
Rep Power: 41 |
yes it failed because of hard edge.. that's why you need to fix it.
Tell me why you don't want to split your surface into 2 surfaces? Sans titre.jpg
February 11, 2011, 07:50 |
#11 |
kostas
Because, i want to distibute nodes at specified length of edge.
Look. I have make a NACA airfoil and i want to run it in transonic regime. I must put, general, few elements (less computational cost) but in region where appear the shock i want dense mesh. Therefore, i need dense mesh only near of hard edge. In residual face the pave method must do its work. Ok. finally i will do as you talk(split at two faces) but i believe that there is a way to disconnect mesh by topology so that to move only mesh in same face without hard edges. Is there? |
February 11, 2011, 07:55 |
#12 |
Maxime Perelli
Rep Power: 41 |
can you post a picture of your model naca?
February 11, 2011, 08:00 |
#13 |
kostas
This is the 2d mesh. The hard edge is appear in above face.
February 11, 2011, 08:17 |
#14 |
Maxime Perelli
Rep Power: 41 |
Then split your surfaces so that your "shock-line" divide a surface into 2 surfaces.
February 11, 2011, 08:35 |
#15 |
kostas
Ok. Thanks. I will do with this way.
February 11, 2011, 12:41 |
#16 |
kostas
Finally, it is working! The cooper scheme work with this way. Look the picture in witch i have split the face in three sub faces.
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
