March 18, 2013, 09:51 |
Prisms Intersection
Sandeep
Rep Power: 17 |
Dear All,
I have got a problem while generating prisms (intersecting prisms), please see attached figure. How can I overcome this problem (like Shrinkage or ignoring prisms there)? Any suggestions or tips could be helpful for me. Thank you Sandeep |
March 19, 2013, 03:19 |
Sandeep
Rep Power: 17 |
I tried with specifing "thin cut" surfaces unfortunately it didnīt help.
Any suggestions how to apply shrinkage or ignoring prisms there (Ex: see attachment) Regards Sandeep |
March 19, 2013, 09:54 |
Rep Power: 24 |
You could try one of the following steps:
- set prism height "0" for floating height in problematic regions - make use of the auto-reduction function which can be found under advanced prism settings. - I would rather go back to geometry and just close the critical gaps if your geometry does not have to be 100% accurate |
March 19, 2013, 10:17 |
Ghazlani M. Ali
Rep Power: 28 |
use simon's tips and trick to find a solution for your problem. worst come to worst, you will need to evaluate the importance of that region (remove the sharp angle if you don't need information there):
https://docs.google.com/file/d/0ByIL...BQT3pQMjQ/edit |
March 19, 2013, 21:09 |
Simon Pereira
Rep Power: 47 |
I was asked by two people to come and comment here, but I think the right things have already been said.
1) refining the mesh size, setting the initial height to 0 (float) and turning on options like "auto reduction" should help. 2) If that fails, then altering the geometry so you don't have such a tight space will help. I have worked on actual industry examples and they usually place a box behind the body (intersecting the body and the seat). In real life the driver wouldn't be leaning forward from the seat anyway, closing off much of that gap will not hurt your accuracy, but it will make the meshing/solving easier. 3) If all else fails and you are interested in trying TGrid Meshing, TGrid Tetra really has advanced over the past few years and its "auto reduction" and handling of situations like this is really superior... Of course, it has its own learning curve, so it may not be for everyone.
----------------------------------------- Please help guide development at ANSYS by filling in these surveys Public ANSYS ICEM CFD Users Survey This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)... CFD Online Users Survey |
intersection of meshes in centrifugal pump | eng_norouzi | CFX | 0 | October 4, 2011 03:45 |
[GAMBIT] 3D mesh for pipe intersection | pranab_jha | ANSYS Meshing & Geometry | 3 | May 28, 2010 01:33 |
Polyline at intersection of two planes | Francesco | CFX | 2 | July 29, 2009 08:03 |
intersection of two cubes. | park | Main CFD Forum | 2 | July 1, 2009 03:19 |
meshing at a pipe intersection | cyn | FLUENT | 0 | December 20, 2006 02:16 |
