Home > Forums > ANSYS Meshing & Geometry
[ICEM] generating new mesh when changing Angle of Attack
Old   February 24, 2011, 08:17
Default generating new mesh when changing Angle of Attack
Nick
Nick R is on a distinguished road
I've created a mesh in ICEM for a 3d wing at zero angle of attack in a square domain.
I'm going to simulate flow over the foil in a windtunnel so the top and bottom boundaries should be set as Wall in CFX but the problem is it seems like I'd have to generate a new mesh for every AOA. I thought changing the free stream velocity direction would help but it doesn't in this case because my top and bottom boundaries are Walls and the lift coefficient turns out much lower than expected. If this were in open space I would set the left and bottom as inlet and that would work fine but this is a wind tunnel-based simulation.
So my question is, is there a way I could rotate my wing in ICEM and still have the same blocking scheme generate a mesh for me? I don't want to construct blocks/associate etc every time I change AOA. Any other suggestion is highly appreciated.
Nick
Nick R is offline   Reply With Quote
Old   February 25, 2011, 16:35
Default Yes, you can script it...
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Blocking is persistent... You could just script it. Make a script that rotates the airfoil and associated blocking and then recomputes the mesh and outputs to the solver...
On the low end, this could just be a replay file you would run manually and change the angle each time.
But a more advanced user could create a loop with an indexing angle that would dump out a series of files pretty easily...
on the youtube ansysinc site, I put a 3 part movie about how to script this with replay. That method actually started from scratch with the script doing everything... But you could also use a smaller script just to handle rotation.
PSYMN is offline   Reply With Quote
Old   February 27, 2011, 03:20
Nick
Excellent. Many thanks.
Old   April 11, 2012, 18:31
Default need help in changing angle of attack in ansys 13
pratik
deltaa42 is on a distinguished road
how can i change angle of attack in ansys 13? Is is better to use ansys workbench or ansys multiphysics utility menu for simulation purpose? thanx for any help in advance.
deltaa42 is offline   Reply With Quote
Old   April 17, 2012, 17:33
PSYMN's Avatar
Simon Pereira
That depends on a lot of factors...
You can rotate portions of geometry in ICEM CFD (just use the geometry => Transformation commands...). If it doesn't change the topology too much, portions of the blocking can be rotated the same way and the mesh will interpolate between. Many users have created scripts that manage the update for them.
You could also use DM or some upstream CAD system to parametrically update the model...
But if you want to rotate the entire model (if you are just looking at just an airfoil), you could just adjust the angle of the flow instead of adjusting the mesh at all...
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
Thread Tools
Trackbacks are On
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
FSI/MFX: folded mesh after changing Air to Water gogohusky CFX 4 April 24, 2012 09:26
snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Native Meshers: snappyHexMesh and Others 2 March 27, 2011 21:11
Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... 2 July 15, 2005 04:15
angle of attack kiran FLUENT 0 September 10, 2004 08:18
