Need help on meshing this simple geometry
Old   March 8, 2011, 09:42
Default Need help on meshing this simple geometry
Nuril
nha1g08 is on a distinguished road
Can anyone help me on meshing the geometry given below.
As you can see I want a flow to go through an inlet, and then go through a conical nozzle. I meshed it once but I get strange results, the flow goes through the walls of the conical nozzle, as shown in the next diagram
It shouldnt happen as i have set the Boundary Condition, for the nozzle wall to be a WALL.
Therefore it is a meshing problem.
Can someone tell me how to mesh this geometry correctly.
Thanks
nha1g08 is offline   Reply With Quote
Old   March 8, 2011, 10:21
AB
BrolY will become famous soon enough
Which software do you use? And what is your solver?
Hexa or tetra?
I guess your geometry is a 2D one? So the conical nozzle is a 2D surface inside your 2D volume. You need to specify this when you create your mesh. And the way to specify it depends on the element type !
BrolY is offline   Reply With Quote
Old   March 8, 2011, 11:42
Nuril
I am using Gambit, and the solver is fluent. Im not sure what type of mesh i used before, i think it might have been tri or hex. Yes the geometry is 2d.
I have made the following geometry in gambit.
But how do you specify element type, how do I make conical nozzle a 2d surface and the rest a 2d volume.
Old   March 9, 2011, 02:13
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
I don't think your problem is linked to element type, else you should have one error while exporting your mesh.
If you build your domain properly, and you don't specify any BC on the nozzle, Gambit will treat nozzle's edges (the 3 edges at the extremity) as interior ,since they are only splits.
As you did, you may enforce Gambit setting the 2 conicals as wall.
By clicking on Specify Color Mode icon (in Global control), your 3 edges have to be displayed as blue (meaning splits and connected)
If you still have problem, you may provide your dbs file for checking
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
[Commercial meshers] Meshing of a geometry modelled in pro-e pabluck OpenFOAM Meshing & Mesh Conversion 0 October 10, 2010 11:50
Problematic geometry in Ansys Meshing ATOTA ANSYS Meshing & Geometry 1 October 9, 2010 11:51
[Other] Geometry and Meshing Questions Flaky ANSYS Meshing & Geometry 6 October 8, 2010 01:10
[Gmsh] Problem meshing an imported geometry Alicia OpenFOAM Meshing & Mesh Conversion 0 March 30, 2010 04:53
Meshing of imported 2-D CAD geometry in STAR-CD Haris Maharana Siemens 1 June 30, 2000 13:48
