Subtract fluid volume to simulate projectile? |
March 4, 2011, 18:08 |
Nick Smith
Rep Power: 15 |
I need to simulate a projectile in a cylinder fluid volume. I make a cylindrical fluid volume and then subtract the shape of the projectile correct? How do I do the subtracting part?
March 7, 2011, 03:31 |
AB
Rep Power: 21 |
Which mesher do you use?
Do you want to do hexa or tetra mesh ? |
March 9, 2011, 22:06 |
Nick Smith
Rep Power: 15 |
I am not sure which mesh I want to use... does it matter at this point or can I wait to fool around with that once I get to the meshing step.
I was told I make a cylindrical fluid volume and then delete from it the shape of my projectile. Is that true at least? lol thanks |
March 10, 2011, 02:45 |
Maxime Perelli
Rep Power: 41 |
With Gambit: create your cylinder (volume), create your projectile (volume)
Substract projectile from cylinder
In memory of my friend Hervé: CFD engineer & freerider Last edited by -mAx-; March 10, 2011 at 03:29. |
March 10, 2011, 03:26 |
AB
Rep Power: 21 |
With ICEM :
If you use tetra mesh, then put a material point inside your cylinder. If the projectile geometry is closed, it would not mesh the inside of this projectile. If you use hexa mesh (blocking), then "cut" the shape of the projectile, and delete the blocks inside it. |
cylinder, fluent, fluid, subtract, volume |
Display Modes | |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 21:14 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
Volume of Fluid and Level Set | Huckleberry Finn | Main CFD Forum | 2 | November 29, 1999 15:17 |
Help With Modeling A Projectile Fluid In Flight. | Dzeff G. | Main CFD Forum | 0 | December 10, 1998 21:24 |
