September 30, 2012, 13:55 |
Gambit
upendra kumar shukla
Rep Power: 13 |
Hi ,
In my gambit version there is no option of projection of point on edge but there is option of projection of edge on plane what i do for projecting point on edge? Thanks in advance. |
October 1, 2012, 08:00 |
Maxime Perelli
Rep Power: 41 |
what is your version?
http://aerojet.engr.ucdavis.edu/gamb...create_project
In memory of my friend Hervé: CFD engineer & freerider |
October 1, 2012, 09:06 |
Rep Power: 13 |
Hi ,
Gambit version is 2.2.30.Here not available. Thanks |
October 1, 2012, 09:08 |
Maxime Perelli
Rep Power: 41 |
ok. can you post a picture to see how is it look like?
October 1, 2012, 10:55 |
Rep Power: 13 |
Hi sir,
Here is the link of this version where u see it is not available in this version http://202.118.250.111:8080/fluent/G...ide/mg0202.htm |
October 1, 2012, 10:59 |
Maxime Perelli
Rep Power: 41 |
I mean how your geometry looks like ( which point do you want to project on which edge)
October 1, 2012, 11:06 |
Rep Power: 13 |
Hi ,
I want to project end points of an arc on the edge. |
October 1, 2012, 11:07 |
Maxime Perelli
Rep Power: 41 |
picture?
October 1, 2012, 11:19 |
#9 |
Rep Power: 13 |
October 1, 2012, 11:24 |
#10 |
Rep Power: 13 |
October 1, 2012, 11:25 |
#11 |
Rep Power: 13 |
October 1, 2012, 12:06 |
#12 |
Rep Power: 13 |
I want to project end point of the circular arc (concave up )on the line lying horizontally below it. |
October 1, 2012, 15:47 |
#14 |
Rep Power: 13 |
Hi sir,
It is not available in gambit version 2.2.30.Here projection of point on edge option not available.Here is the link of this version where u see it is not available in this version http://202.118.250.111:8080/fluent/G...ide/mg0202.htm |
projection |
Display Modes | |
Gambit Startup Window | Jay Shim | FLUENT | 2 | February 12, 2015 15:05 |
Gambit help: Cube inside cube | Jack Martinez | FLUENT | 13 | August 11, 2010 07:29 |
Gambit 2.3.16, Xming or Exceed...HELP! | bambam3417 | FLUENT | 10 | May 7, 2010 13:39 |
Gambit -dev X11 doesn't work | Ervin Amet | FLUENT | 0 | October 28, 2007 09:33 |
Generating big meshes with GAMBIT on NT | Andrew Ooi | FLUENT | 12 | February 2, 2000 23:26 |
