from gambit to ansys fluent
hi!
i'm a new user of Ansys, but i'm only interested about Fluent. I have a mesh that I have made in Gambit, and I want to work with it in Ansys Fluent. I would like to know what solver must I choose in Gambit?how I exported the mesh and how i read it then in Ansys Fluent? thanks |
Works the same...
It can all be done the exact same way as for Fluent...
You would output a *.msh file and read it in to Fluent... You could run ANSYS Fluent on its own and it would be pretty much the same as the Fluent you are used to, or you could run it thru ANSYS Workbench to take advantage of other connections... You can right click on ANSYS Fluent in WB to attach the *.msh file from Gambit. |
| All times are GMT -4. The time now is 18:47. |
