-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   Heat transfer with ANSA (http://www.cfd-online.com/Forums/ansys-meshing/86239-heat-transfer-ansa.html)
tH3f0rC3 March 17, 2011 10:47
does someone know how I can set the boundary conditions in ANSA for a heat transfer? I want to solve this case with OpenFoam (maybe this information is necessary for you).
Where can I type in the heat transfer coefficients? Is it the Numerical Type k in the shell property listed in PIDs?
Is the heat transfer coefficient from air to a wall set as a property of the wall or of the air?
I want to know the meaning of the different values listed under Shell property (k, epsilon, nut,...). Does someon have a list, or knows where these values are listed with their meaning? I have checked the User's Guide (ANSA v13.0.2) without success.
Thank you for your support.
Regards,
Dirk
