March 23, 2011, 05:26 |
query for help
anonymous
HI ALL ;
I am using ICEM CFD 11. after making a geometry and seting up parts ( inlet,outlet, ...) and meshing succefully then I extruded the 2D mesh to import it in CFX PRE . All seems right but I lost parts ( inlet,outlet ...) when I was seting up Boundary conditions in CFX PRE. so whet's the problem please. If any one can help. |
March 24, 2011, 04:37 |
Firstly in the export section of ICEM-CFD there are options where you specify the nature of bcs such as inlet for velocity inlet.
This is the proper way of preprocessing the mesh in ICem In all probablity the problem lies in what you are doing in CFX. If you have done the preprocessing as stated above the parts should appear once you say inlet, the inlet will be selected by default. |
March 24, 2011, 16:31 |
Inherited...
Simon Pereira
Rep Power: 47 |
In 2D, did you have lines in the parts (INLET, OUTLET, etc.)?
When you extruded 2D to 3D, those lines should have become shells... You need to use the inherited option rather than naming these side parts as something specific... I usually set inherited for the sides, but name the top (Side2) and Volume (FLUID). |
March 25, 2011, 17:19 |
anonymous
thank you simon
how to query node coordinates? | phsieh2005 | OpenFOAM Post-Processing | 3 | November 26, 2018 20:13 |
yPlus query | vw.cfd | OpenFOAM | 11 | March 10, 2010 14:39 |
query on valid entity | Sharon | FLUENT | 5 | October 16, 2006 05:29 |
query | sihat | FLUENT | 0 | June 18, 2006 21:00 |
query on dynamic mesh | david raju | FLUENT | 1 | June 17, 2006 23:53 |
