March 26, 2011, 07:39 |
Ansys error
Arnold
I installed ANSYS V13.0 on my windows vista pc. I installed ANSYS 13.0 with all the sub programs; AQWA, ASAS, Fluid dynamics, APDL and more! And I installed the License manager too. But I have a problem to start Ansys. There is a problem, see first figure. After I clicked on "OKAY" then the next figure appeared.
I think there is a problem in de ANSLIC_AMDIN lincense manager. If you look in the third figure, @ left bottom, there is a figure called PC status. Everthing is running, except the FLEXlm. I think the problem is solved if i can start FLEXlm running, but i don't know how? Thank you! Grtz, Arnie |
March 27, 2011, 19:53 |
lmgrd.exe
Simon Pereira
Rep Power: 47 |
Probably a problem with lmgrd.exe.
Ctrl-alt-delete to pull up your task manager... Find the lmgrd.exe and kill the process. You may even have several, kill them all. Then go back to the ANSYSLIC Manager and hit the button to stop everything, and then hit the button to restart the license manager... This should restart lmgrd.exe so flex lm will be running. I don't know why flexlm does that on windows some times...
----------------------------------------- Please help guide development at ANSYS by filling in these surveys Public ANSYS ICEM CFD Users Survey This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)... CFD Online Users Survey |
Compile calcMassFlowC | aurore | OpenFOAM Programming & Development | 13 | March 23, 2018 07:43 |
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! | alban | Fluent UDF and Scheme Programming | 2 | June 8, 2010 18:54 |
POSDAT problem | piotka | STAR-CD | 4 | June 12, 2009 08:43 |
[Netgen] Installation of Netgen in SuSE Linux 92 | edvardsenpriv | OpenFOAM Meshing & Mesh Conversion | 23 | January 16, 2009 06:12 |
How to get the max value of the whole field | waynezw0618 | OpenFOAM Running, Solving & CFD | 4 | June 17, 2008 05:07 |
