[ICEM] Ramjet inlet meshing problem
Old   March 25, 2011, 17:56
Default Ramjet inlet meshing problem
Husein
Husein is on a distinguished road
Im quite new to ICEM, I am working on a project to design a ramjet inlet and I have created the geometry in catia and had no problems importing it in ICEM , but when I give the global mesh parameters, curve mesh par, part mesh setup, and say compute the mesh goes on to 10,000,000 tetrahedrals and the computer hangs, what maybe the problem and possible solutions. Please help
Husein is offline   Reply With Quote
Old   March 26, 2011, 20:38
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
You problem is that somewhere in your model you have a tiny size mesh parameter relative to the size of your model.
Measure your model (use the measure tool in the utilities icons, 2nd row, 3rd icon, it may be under a pulldown icon), so you know how big it is... Maybe you think it is in meters, but it is in mm.
Then check your mesh sizes... Check your global min and max, check sizes on curves and surfaces... If you haven't spent too much time setting things up yet, just go to params by parts and put in new sizes that will over ride everything...
Basically, make sure that your sizes are appropriate.
If you think it all looks good, and doesn't need adjusting, then increase your scale factor (mesh => Global Params) by a factor of 10 and mesh again.
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   March 27, 2011, 03:02
Husein
Thank you so much, you are a saviour
Inlet boundary condition problem Martin_D FLUENT 1 January 10, 2013 12:58
total pressure boundary problem ==> flow from outlet to inlet!! mrshb4 OpenFOAM 0 November 20, 2010 12:41
Diffuser inlet boundary condition problem Attesz CFX 0 April 4, 2009 04:24
problem meshing with low y+ cesco FLUENT 8 February 23, 2009 05:12
Meshing problem in GAMBIT Vidya Raja FLUENT 0 May 20, 2006 23:31
