[DesignModeller]Patterning with zero spacing
Old   March 31, 2011, 03:58
Default [DesignModeller]Patterning with zero spacing
ckbenjamin is on a distinguished road
I tried to imprint a square on solid block and patterning the face 10 times into the x-direction.
However, it does not allow me to have a zero spacing between each imprint. The spacing causes lots of meshing problems thereafter.
Is it possible to pattern without this spacing? Or can other Ansys-friendly CAD software able to do this?
ckbenjamin is offline   Reply With Quote
Old   April 2, 2011, 10:18
PSYMN's Avatar
Simon Pereira
A zero pattern doesn't make any sense... that would just copy over its self.
The spacing is center to center, not the gap between...
If you mean the squares should be right next to each other (zero gap) then the spacing should be the same as the edge size of the square or the distance between centers...
CFD Online Users Survey
Old   April 3, 2011, 09:16
Yes i meant zero spacing. DM doesn't allow that. Have you tried?
Gridgen node spacing Vincent Pointwise & Gridgen 4 August 7, 2016 17:33
element size control in ICEM (line & face spacing) Sam CFX 0 January 28, 2008 13:28
Using grid spacing calculator for laminar flow CH Main CFD Forum 0 November 5, 2006 00:02
small node spacing Gary Holland FLUENT 13 June 10, 2005 10:06
Spacing Factor Alexandre Siemens 1 December 21, 2002 03:21
