September 28, 2010, 21:39 |
Import from ProE 5 to ansys 12.1
hun
Rep Power: 16 |
HI
I tried to import from ProE 5 to ansys 12.1 but the result seems a bit funny. any suggestion? thanks |
December 6, 2010, 17:17 |
Insider Insight
Simon Pereira
Rep Power: 47 |
I asked some insider types about this and was told...
"Seems like the faceting is coarse. If they are using DM, there is an option (Tools -> Options -> DesignModeler -> Graphics -> Facet Quality) to increase facet quality. They can also improve the accuracy in Pro/Engineer. If they are inside mechanical they can try to mesh it to see if it is just a display issue or real problem with the geometry. If it remains unresolved they should contact ANSYS support with the model. We can look at it more closely once we have the geometry." Anyway, let us know if this helps... |
March 31, 2011, 20:07 |
hun
Rep Power: 16 |
It work perfectly.
thanks Hung |
Evaporation model in ansys Fluent 12.1 | oldisbest | Fluent UDF and Scheme Programming | 12 | March 26, 2020 09:11 |
How I could import Ansys mesh into CFX? | mahdi57 | ANSYS Meshing & Geometry | 8 | August 9, 2013 04:49 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
problem in import ANSYS mesh | sheryl | CFX | 2 | April 30, 2005 21:30 |
import Fluent data&case to ANSYS | Vlad S | FLUENT | 0 | April 2, 2003 05:49 |
