April 24, 2011, 17:55 |
Boundary layer in the corner
I will be grateful for info how to deal with the 2d boundary layer on highly convex boundaries ("corners") in GAMBIT. How to fix boundary layer shown on the image attached? I have set "internal continuity" option. Truffaldino |
May 2, 2011, 02:56 |
Maxime Perelli
Rep Power: 41 |
your BL seems to be to thick
In memory of my friend Hervé: CFD engineer & freerider |
May 6, 2011, 08:56 |
Yes it is thick for Gambit, but represents quite correctly the problem: a small step at the airfoil at low reynolds number. In my case bl size is of order of 1 mm at Re=50000, while the step size is of order of 5-10 mm.
May 6, 2011, 09:05 |
Maxime Perelli
Rep Power: 41 |
if the BL is to thick, Gambit should failed to create it.
In your case Gambit creates something. If you want you can send me your dbs file, I will take a look on monday
May 7, 2011, 07:57 |
#5 | |
I have already solved the problem (see image below). I have just meshed edge containing corner using curvature size function. Truffaldino |
[Gmsh] Default Faces on Boundary Layer | axel | OpenFOAM Meshing & Mesh Conversion | 8 | February 17, 2011 07:47 |
[GAMBIT] problems in boundary layer | yubaibai88 | ANSYS Meshing & Geometry | 8 | April 19, 2010 21:07 |
Adapt mesh without modifying boundary layer cells? | Freeman | FLUENT | 0 | February 22, 2009 14:11 |
3D Boundary Layer | Mario | FLUENT | 0 | February 17, 2009 03:40 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
