Home > Forums > ANSYS Meshing & Geometry
[ICEM] Help making Surface Urgent !!!!
Old   April 13, 2011, 05:14
Default Help making Surface Urgent !!!!
anonymous
fek66 is on a distinguished road
Hi All ;
If anyone help me to make surface on two sides of model described in the picture .
fek66 is offline   Reply With Quote
Old   April 13, 2011, 05:45
anonymous
Originally Posted by fek66 View Post
Hi All ;
this is the result when selecting curves to make surface !
Old   April 13, 2011, 10:45
Retired from CFD Online
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
You are trying to loft, that works if the curves are roughly parallel. It tries to connect each curve in the series...
What you need is Create surface from 2 to 4 curves... You actually have more, but they are planar so it can figure it out.
If the first attempt fails, it may give a large untrimmed surface. Just run build topology and it will trim that surface. Then you can delete the outer portion.
Another option is to just create a surface (2 to 4 curves from the inlet and outlet side curves... Then trim out the two small squares (using build topo and then delete).
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   April 13, 2011, 11:50
anonymous
I try to make surface but still one problem as described below in figure.
Old   April 13, 2011, 12:43
PSYMN's Avatar
Simon Pereira
Odd, you could either fill that in with another surface, or you could try my second suggestion and stretch a surface from one side of the box to the other (just using 2 curves) and then build topo and cut out the small boxes...
Thread Tools
Trackbacks are On
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
boundaries with gmshToFoam‏ ouafa Open Source Meshers: Gmsh, Netgen, CGNS, ... 7 May 21, 2010 12:43
Recover surface from surface mesh in IcemCFD Jerry Tanner CFX 0 August 20, 2008 12:48
Making arc on circle surface rosol FLUENT 2 October 11, 2007 13:55
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin Kaushik FLUENT 1 May 8, 2000 06:47
