April 13, 2011, 05:14 |
Help making Surface Urgent !!!!
anonymous
Hi All ;
If anyone help me to make surface on two sides of model described in the picture . |
April 13, 2011, 05:45 |
anonymous
this is the result when selecting curves to make surface !
April 13, 2011, 10:45 |
Simon Pereira
Rep Power: 47 |
You are trying to loft, that works if the curves are roughly parallel. It tries to connect each curve in the series...
What you need is Create surface from 2 to 4 curves... You actually have more, but they are planar so it can figure it out. If the first attempt fails, it may give a large untrimmed surface. Just run build topology and it will trim that surface. Then you can delete the outer portion. Another option is to just create a surface (2 to 4 curves from the inlet and outlet side curves... Then trim out the two small squares (using build topo and then delete).
----------------------------------------- Please help guide development at ANSYS by filling in these surveys Public ANSYS ICEM CFD Users Survey This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)... CFD Online Users Survey |
April 13, 2011, 11:50 |
#4 | |
anonymous
April 13, 2011, 12:43 |
Simon Pereira
Rep Power: 47 |
Odd, you could either fill that in with another surface, or you could try my second suggestion and stretch a surface from one side of the box to the other (just using 2 curves) and then build topo and cut out the small boxes...
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 06:41 |
[Gmsh] boundaries with gmshToFoam | ouafa | OpenFOAM Meshing & Mesh Conversion | 7 | May 21, 2010 12:43 |
Recover surface from surface mesh in IcemCFD | Jerry Tanner | CFX | 0 | August 20, 2008 12:48 |
Making arc on circle surface | rosol | FLUENT | 2 | October 11, 2007 13:55 |
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin | Kaushik | FLUENT | 1 | May 8, 2000 06:47 |
