Simple pipe layout - 2 pipe joined by a 90 degree elbow
Old   April 25, 2011, 02:41
Question Simple pipe layout - 2 pipe joined by a 90 degree elbow
GamFlu is on a distinguished road
Hi I am new user and needs help from cfd experts, trying to make simple pipe layout i.e. 2 pipes; 1 horizontal and 1 vertical joined by 90 degree elbow at the base of vertical, here is what i have done, define vertices and manage to make horizontal and vertcial by sweep face commands, however the sweeping fails for elbow. any suggestions will be appreciated.
GamFlu is offline   Reply With Quote
Old   April 26, 2011, 07:56
Question flow in pipe
manage to solve the above problem .......... however i am stuck in FLUENT, I AM TRYING TO SIMULATE A SINGLE PHASE WATER FLOW IN VERTCIAL PIPE HAVE EXPERIMENTAL VALUES OF GAUGE PRESSURE ... NEED TO COMPARE WITH FLUENT VALUES .. WHAT SHOULD BE THE OPERATING PRESSURE 101325Pa or 0 value.
[ICEM] Using a hybrid mesh for a simple pipe Udio_NT ANSYS Meshing & Geometry 17 October 18, 2012 14:42
Appropriate model for turbulent, steady state pipe elbow flow milos OpenFOAM Running, Solving & CFD 4 July 9, 2009 02:24
Grid Independence problem for simple pipe geometry chanchala FLUENT 13 November 20, 2003 08:24
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
