April 4, 2010, 18:57 |
H-O-H-Mesh on T106A Turbine Blade
Joshua Counsil
Rep Power: 17 |
Hello all -
Problem: I have searched up and down this forum and online for a tutorial on how to create an H-O-H-grid for a turbomachinery problem. I have completed most of the tutorials on the portal (2D pipe, 3D pipe...), but none of them seem to cover my specific problem. I noticed people mentioning a stator tutorial, which could be useful, but I could not find it. I did find the .zip files of ICEM PowerPoint lectures somebody posted. They were somewhat useful, but still didn't answer my problem. I will be importing the mesh into CFX. Here is the geometry: [img=http://img101.imageshack.us/img101/7696/icemt106ageom.th.jpg] The first square inlet region is the first H-grid section. I then want an O-grid around the airfoils (the top section is the pressure surface, the bottom is the suction surface), followed by a transition to another H-grid in the rectangular outlet. Method: I blocked the domain like this: [img=http://img694.imageshack.us/img694/7884/icemblocking1.th.jpg] With the associations shown: [img=http://img706.imageshack.us/img706/5061/icemblocking2.th.jpg] The thought process here is that I want the first and last blocks to be simple, structured H-grids. The airfoil block has an O-grid split (the blue square). The diagonal block after the airfoils will be a transition region between the O- and H-grids. I'd like the O-grid to be orthogonal to the airfoil, and refined for proper boundary layer capturing. I know how to make the entire domain unstructured prisms. I know how to create a fully structured H-mesh with specified nodes. I don't know how to implement both in the same simulation. Any help would be much appreciated, whether it's simple advice, tutorials, or (bonus) instructions. |
April 6, 2010, 20:58 |
Joshua Counsil
Rep Power: 17 |
Any help? I will be taking ICEM workshops over the summer when we receive our new budget, but I have a conference before then and need to have this simple simulation to present.
Please don't think I'm being lazy. I've blown 6 work weeks on this already, but can't seem to get any help. |
May 10, 2011, 03:50 |
mohammad
Rep Power: 16 |
Hi Joshua,
I have the same problem as yours. I Think you can help me now. Do you have any idea how to create HOH grid? regards |
May 10, 2011, 04:29 |
jeevan kumar
Rep Power: 17 |
Hello Josh,
can you just sketch and show how you want a H-O-H grid (free hand sketch). if possible can you upload the geometry, so that i can make you the required topology for you. Thank you jeevan |
May 10, 2011, 04:34 |
#5 | |
mohammad
Rep Power: 16 |
can you help me to have some general info and some pics of HOH grids. I'm just beginner in HOH. TNX a million |
May 10, 2011, 14:01 |
Joshua Counsil
Rep Power: 17 |
Hey guys -
Please read this thread: http://www.cfd-online.com/Forums/ans...-elements.html It solved my problems. Good luck. |
Display Modes | |
Virtual Blade Model (VBM) for wind turbine. | teymourj | FLUENT | 27 | July 4, 2018 07:03 |
Can I use Turbogrid to mesh a wind turbine blade? | Henry Liu | CFX | 10 | November 10, 2011 05:41 |
[ICEM] Blade passage block mesh in ICEM | Attesz | ANSYS Meshing & Geometry | 4 | February 13, 2010 04:53 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
how to obtain mesh file of cooled turbine blade | rajesh kumar gupta | FLUENT | 0 | October 18, 2007 04:18 |
