[TurboGrid] Unhandled Exception Error
Old   June 1, 2020, 15:31
Default Unhandled Exception Error
Tate
t8fanning is on a distinguished road
I'm getting an unhandled exception error after successfully generating a mesh and closing Turbogrid. The error only occurs upon closing Turbogrid to get back to Workbench.
This shows the error message, but it is an object reference not set to an instance of an object error. Any ideas how to fix it? I've tried deleting the ANSYS %APPDATA% files, but that hasn't helped yet.
t8fanning is offline   Reply With Quote
Old   June 2, 2020, 11:53
Tate
I've determined this error occurs with Turbogrid or CFX, but only after I've saved the workbench file.
Old   June 3, 2020, 11:29
Tate
I've found some more information. The error only occurs once I've moved the workbench files from the local machine to my storage drive and open it from there. The error does not occur if I try to open it from the local drive, even if it has been moved to the storage drive at any point.
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 00:21
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 07:43
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 11:39
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 05:07
