[ICEM] Prism generation
Old   April 20, 2011, 11:23
Default Prism generation
AB
BrolY will become famous soon enough
My question is about the prism generation:
Here are my specifications : 3 layers of prism with an initial height of 0.0025 and a growth ratio of 1.3.
If i specify those values in the "Part Mesh Setup", how does ICEM generate the prism? Does it calculate the total height, then push the tetra, and finally cut the prism into 3 parts ? Or does it push the tetra, then create the first layer, then push again the tetra for the 2nd layer etc.. ?
I know ICEM allows to create one layer then split it, but this leads to create pyramisd (which I must avoid) if the 2 walls are too close from each others.
Thanks,
BrolY is offline   Reply With Quote
Old   May 7, 2011, 12:36
Lorenzo Mazzei
Mazze[ITA] is on a distinguished road
the second one you told.
Mazze[ITA] is offline   Reply With Quote
Old   May 16, 2011, 08:57
Vijaya Sekhar Gullapalli
gullapallivijay is on a distinguished road
You can use the option "Auto Reduction" together with Laplace smoothing of surface elements to prevent formation of pyramids between close surfaces. Splitting method for prisms is recommended since the last layer is created with similar volume as the adjacent tet
gullapallivijay is offline   Reply With Quote
[ICEM] prism generation jsm ANSYS Meshing & Geometry 19 September 22, 2017 02:44
[ICEM] Fixing tetra Surface Orientations after prism generation siw ANSYS Meshing & Geometry 14 December 1, 2015 15:54
problem in prism layer generation shrimp CFX 5 March 26, 2010 12:34
[Need Help] Prism layer generation using gridgen Amstrong Pointwise & Gridgen 0 November 16, 2009 02:16
need help on Prism Mesh Generation Pete CFX 0 December 6, 2004 02:11
