-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [DesignModeler] modelling a bent pipe (http://www.cfd-online.com/Forums/ansys-meshing/88403-modelling-bent-pipe.html)
Prakash.Paudel May 17, 2011 01:02
I want to model a solid pipe that is curved and i know the equation of that curve. I need this solid model to simulate fluid flow through this pipe. what is the best way to create this solid pipe.
This is what i did:
I imported "formatted point data" in design modeler and created a curve on a plane using these data points. I sketched a circle on a plane normal to the first plane and I tried to sweep this circle along the curve but design-modeler wouldn't let me select this curve as sweep path ( I suppose the reason is that the sweep path has to be a sketch and not a curve) .
Does anyone have solution to this problem?? Thanks for any help
Prakash
