-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   Geometry creation (http://www.cfd-online.com/Forums/ansys-meshing/88404-geometry-creation.html)
kmgraju May 17, 2011 01:10
Geometry creation
1 Attachment(s)
Dear all
Please find the attached graph which is constructed by a mathematical function.
My question is
I want to construct a solid model using this function in ANSYS work bench.
How to construct the model in ANSYS work bench?
If not any other way to construct a model for further analysis?
Thank you
Regards
Govind
gullapallivijay May 17, 2011 07:47
Perhaps you can use the "Run Script" functionality in design modeler to generate sketch in the active plane and then create a solid from that base sketch. Example of sketch scripts are found on the web, for example, http://www.kxcad.net/ansys/ANSYS/wor...iteScript.html
kmgraju May 17, 2011 11:58
geometry
Dear friend
Thanks for your tips. I would like to know where can I find the scripting commands for the work bench. Suppose I want to apply sin and cos function to develop my geometry how to use the function.
Thank you
Regards
Govind
