Home > Forums > ANSYS Meshing & Geometry
[GAMBIT] How to mesh this entity with sharp corner?SOS!
Old   May 18, 2011, 22:52
Default How to mesh this entity with sharp corner?SOS!
J.G.Wang
W.T.S is on a distinguished road
Dear Everybody, I'm now meshing a volume which has pointed corner as shown below, the skewness of tens of elements will always be higher than 0.97 after meshing first line then face then volume.No matter how i move the points on the face manually, it can not show a good quality. a guy told me since there're two connected lines ending up to a tangent profile, no way the quality of this face will be improved too much. Is that true?
Another problem is, after moving grids on the face, the equisize skewness of the face will be improved from 0.983 to 0.968, so gambit shows no error or warning. but i import the mesh file to the fluent and smooth and use case check, it told me the skewness exceed 0.98 in 5 elements thread id is 2. That's why?Haven't I lower the skewness to 0.96?
I'm waiting for your kind helps.
W.T.S is offline   Reply With Quote
Old   May 19, 2011, 01:58
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
avoid having sharp angle.
In your case, I think you need to delete it.
Split your geometry short before the sharp angle, and delete the volume containing the sharp angle.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   May 19, 2011, 02:56
Default thank you!
J.G.Wang
Attachment 7775
Thank you very much! But will it affects the results too much since the model will not be the same one any longer?
Old   May 19, 2011, 03:02
-mAx-'s Avatar
Maxime Perelli
I don't think it will affect the solution, since this is not an high velocity or pressure-gradient.
Anyway you won't be able to get an acceptable mesh if you don't fix it
Old   May 19, 2011, 04:45
Default Thank you.
J.G.Wang
Thanks a lot for your quick reply and guidance. I'll try fixing it with this method. thank you again, -mAx-!
Old   May 25, 2011, 01:32
J.G.Wang
what if i use stairstep function in hex meshing?
J.G.Wang
Old   May 25, 2011, 01:57
-mAx-'s Avatar
Maxime Perelli
if the topology remains, the mesh has to follow it( especially at boundary egde/surface).
And it is indepedant from the kind of mesh you will use
In other words you will still have problem at the corner
Old   May 25, 2011, 09:37
Unhappy
J.G.Wang
thankyou!although i'm afraid if i cut the volume, the solution will be changed because it is connected to another entity. the entity i showed you is the inlet of a hydrocyclone. as shown below.thank you all the same,-Max-!You've helped me a lot!2011-05-25_213202.jpg
Old   May 25, 2011, 09:54
-mAx-'s Avatar
Maxime Perelli
merge it with the volume, which is tangential to sharp angle.
Old   May 25, 2011, 10:05
J.G.Wang
well, merging them doesn't help anything, the sharp corner can't be avoided.2011-05-25_220245.jpg
Old   May 26, 2011, 10:23
-mAx-'s Avatar
Maxime Perelli
For instance you can do an extrusion of your volume 8 in x-direction (<0).
More in details: sweep surface.6 with (-0.1 0 0).
Then unite volume 8 with the new one.
And you don't have your sharp corner
Old   May 26, 2011, 11:10
J.G.Wang
I know what you mean, thank you very much! Hope it will not affect the solution. You've helped me so much indeed.
Thread Tools
Trackbacks are On
Number of cells in mesh don't match with size of cellLevel colinB OpenFOAM Native Meshers: snappyHexMesh and Others 11 January 13, 2015 12:47
engrid -> save as .stl with boundarie codes Zymon enGrid 31 August 29, 2011 13:40
Structured mesh of a 3d sharp trailing edge Gilles Main CFD Forum 2 May 23, 2008 13:23
basic of mesh refinement arya CFX 4 June 19, 2007 12:21
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 11:09
