-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   Merge 2 unstructured meshes (http://www.cfd-online.com/Forums/ansys-meshing/88548-merge-2-unstructured-meshes.html)
vinc May 19, 2011 16:14
1 Attachment(s)
I use ICEM CFD v12.1. My geometry is very simple. As you see on the attached figure, I have two cubes sharing a common interface. The mesh inside the buttom cube was created with octree method. The mesh inside the top cube was created with blocking method, but I created only penta elements inside this blocking. At the commun interface between the two cubes, the mesh is perfectly connected node to node. I converted the mesh inside the top block in unstructured mesh. So I have two unstructured meshes sharing a commun interface and at the interface the two meshes are connected node to node.
After that, I check the mesh with check mesh tool in ICEM and it says: «656 problems were found for Penetrating elements».
How do I successfully merge the two meshes???
Best Regards,
Vinc
