Home > Forums > ANSYS Meshing & Geometry
measurement of geometry
Like Tree1Likes
  • 1 Post By -mAx-
Old   May 23, 2011, 10:02
Default measurement of geometry
Lilly is on a distinguished road
Hello everybody,
I created a complex geomtry, imported it to Gambit and meshed it. Does anybody know whether there is a way to measure this geomtry (length of the single parts, diameter etc.)? I have seen that there is a "ruler option" at Gambit, but due to the complexity of the problem it would much better, if I could select two points of the geometry and measure the length in between (or something similar). Does anybody know how I could solve this problem (maybe by using another software/freeware which can import *.neu or *.msh files.The software I have access to is Gambit and Fluent). Unfortunately I cannot save the geometry as *.stp or *.igs, due to non-real parts at the geometry.
Thank you in advance!
With best regards,
Lilly
Lilly is offline   Reply With Quote
Old   May 24, 2011, 03:35
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
to measure distance between 2 points, here is what I do:
Create edge from the 2 points, and go to summarize edges.
It will give you the length from the edge.
Then delete your edge if you don't need it anymore.
stage81 likes this.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   May 27, 2011, 10:05
That's a good advice! Thank you -mAx-!
Old   June 23, 2015, 04:41
Default it works for me!
atena
atenamsv is on a distinguished road
just go to volumetric geometry and there's an "i" (summerize volume) icon click on it tjen select your volume, now u can see the detail on transcript box
atenamsv is offline   Reply With Quote
Thread Tools
Trackbacks are On
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 20:42
[ICEM] O-grid around wing geometry Anorky ANSYS Meshing & Geometry 12 August 17, 2011 21:28
Problem meshing an imported geometry Alicia Open Source Meshers: Gmsh, Netgen, CGNS, ... 0 March 30, 2010 04:53
Simulation of Flow through Complex 3D Geometry EmersonKB CFX 5 July 2, 2009 08:17
vitual _ real deneb FLUENT 3 January 22, 2007 05:31
