Home > Forums > ANSYS Meshing & Geometry
[GAMBIT] 3d boundary layer
Old   May 26, 2011, 05:29
Default 3d boundary layer
truffaldino's Avatar
truffaldino is on a distinguished road
I am meshing a segment of 3D wing as shown on the image attached. This is an airfoil in x-y plane translated along z-direction. I have set periodic boundary conditions (linked x-y end faces) in z-direction and set 2d boundary layer(s) on the end x-y plane(s). The wing surface is meshed as quad split.
My question is now: if I mesh the volume around the wing with tet/hybrid, will GAMBIT take those 2d boundary layers into account and create 3d bl zone at the wing surface putting tetrahedra on the top of it afterwards, or it will mesh everythyng with tetrahedra/pyramid instead?
I have tried to mesh it with tet/hybrid, but I could not see the results: If there is an option in gambit which allowes to see bl-part of the mesh (if it exists). I have tried to use standard visualisation of 3D bl, but it does not show anythisng as iI have not created 3D bl.
And another question, even if GAMBIT creates 3D bl, how will it cope with transition between top and bottom 2d bl at the trailing edge (see image)?
Will be grateful for your help.
Truffaldino
truffaldino is offline   Reply With Quote
Old   May 27, 2011, 03:13
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
for 3d domain, create 3d BL.
Just pickt surfaces instead of edges in the BL panel
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   May 27, 2011, 03:58
Thanks mAx,
I have tried this before posting my question, but it does not give good transition between top and bottom bl at the trailing edge.
I have attached images of a good transition between 2d bl at trailing edge, and unacceptable transition in the case of 3d bl attached to the wing surfaces.
If there is a way to mesh 3d domain ising 2d bl on its periodic borders?
Truffaldino
Old   May 27, 2011, 04:57
-mAx-'s Avatar
Maxime Perelli
Ok I see.
Try to extrude the trailing edges.
It will create surfaces, which can be used to split your domain.
Then use them to extend your BL over those surfaces.
It will give you a better wake resolution, and should solve your problem.
Old   May 27, 2011, 16:34
Thanks mAx,
I have used your advice, but rounded TE instead of extruding and then applied curvature size function. In this way I can avoid domain splitting and hope to reuse my journal file for multiple-airfoil configurations with minor corrections.
Truffaldino
Thread Tools
Trackbacks are On
Default Faces on Boundary Layer axel Open Source Meshers: Gmsh, Netgen, CGNS, ... 8 February 17, 2011 08:47
Boundary Layer Question scottneh STAR-CCM+ 3 September 30, 2010 14:21
Adapt mesh without modifying boundary layer cells? Freeman FLUENT 0 February 22, 2009 15:11
3D Boundary Layer Mario FLUENT 0 February 17, 2009 04:40
Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... 2 July 15, 2005 04:15
