Home > Forums > ANSYS Meshing & Geometry
equisize skew
Old   May 29, 2011, 15:03
Default equisize skew
sofia
sofie1 is on a distinguished road
Hello every body;
I am trying to mesh a wavy wall cylindrical geometry with gambit for exporting it to fluent,but i encounter a problem in meshing edge and volume i d'nt anderstand what is the mean of mesh of volume contains skewed elements(equisize skew>0.97) volume contains 3458inverted elements (negative volume), with this message i can't checking this mesh in fluent ,how can i correct this error?
sofie1 is offline   Reply With Quote
Old   May 30, 2011, 06:47
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
once your volume is meshed, go to examine mesh.
Set the lower value to 0.97 and update.
Gambit will show you all cells with skewness over 0.97.
If they are accumulated at a same place, then there is a topoloby problem, that you should fix
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Thread Tools
Trackbacks are On
Cell skew Factor prapanj OpenFOAM Pre-Processing 7 August 25, 2013 15:44
Skew factor of decomposeParDict jms OpenFOAM 1 May 29, 2013 12:12
Avoiding Skew in Tight Corners Marc FLUENT 4 July 23, 2007 15:21
equiangle skew with tetrahedral cells Wouter FLUENT 0 December 7, 2005 06:03
how to reduce Cell Equivolume Skew santosh FLUENT 1 August 16, 2005 14:38
