[ICEM] Can’t get 2D Blayer in hex mesh to be accurate O-block around airfoil
Old   May 30, 2011, 14:42
Default Can’t get 2D Blayer in hex mesh to be accurate O-block around airfoil
Mike
josip76 is on a distinguished road
I’m having problems with setting up a 2D Blayer in ICEM. I'm meshing an airfoil and have my blocking structure built as per the tutorial online by Simon P. However, I want to add an O-grid around the airfoil where the mesh will radially propagate from the surface of the airfoil toward the outer domain to better resolve the boundary layer. Just as in the ICEM hex – tutorial. So to do this I first enabled VORFN to see all the blocks which looks like this:
Following this I selected split block, O-block and clicked the block at the center of the airfoil and enabled the offset and set the set it to 1 and then clicked apply and this is what was the result:
The O-block was not really created as an o-block but rather ended in a sharp point. As such the blocks are very distorted and to compensate for that ICEM seems to have extended the end of the O-block to a distance far off to the right outside the farfield. I was wondering how to fix this, to get an actual O-block around the airfoil so that I can have an orthogonal mesh coming off the surface.
Thanks in advance for the help
josip76 is offline   Reply With Quote
Old   June 1, 2011, 07:48
jeevan kumar
jeevankumarb is on a distinguished road
The blocking you have made will enable you to create a C-grid rather than a O-grid, which you already have only you have to reduce the size of it. For a airfoil C grid is always preferred rather than a O-grid. If you want to create a Ogrid then you should not colapse wake block and the block inside the airfoil. So recreate the block inside the airfoil or take it from vorfn and modify your blocking in order to have a wake block . then just select the block inside the airfoil for O-grid creation.
regards
jeevan
jeevankumarb is offline   Reply With Quote
Old   June 4, 2011, 18:03
Mike
Hey Jeevan,
Thanks for the reply. I tried both both approaches and ur right the C-grid worked much better. There was a huge anount of skew that was created with the use of the 0-grid esspecially near the trailing edge.
Mesh geometry over airfoil with Gambit laith FLUENT 5 March 9, 2018 01:56
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[Commercial meshers] Icem Mesh to Foam jphandrigan OpenFOAM Meshing & Mesh Conversion 4 March 9, 2010 02:58
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
hex mesh vs. tet mesh (for FEM solvers) Sam Main CFD Forum 0 July 1, 2005 15:11
