[GAMBIT] negative volume by cooper?
Old   May 31, 2011, 05:06
Default negative volume by cooper?
J.G.Wang
W.T.S is on a distinguished road
Hi, dear -MAX-, hi everybody! I don't know why when i use the cooper tool in gambit's volume meshing, it produced many negtive volume even if it 's a rather simple entity. I'm here for help...001.jpg
W.T.S is offline   Reply With Quote
Old   May 31, 2011, 07:21
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
*top picture is clear >> not right mesh schema is used
*bottom picture >> check the mesh on axial direction.
You should habe a nice hexa mesh, else Cooper might have problems
The problem doesn't come from the face pointing in our direction
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   May 31, 2011, 07:40
J.G.Wang
Sorry ,i'm still not clear, the top one and the bottom one are the two faces of the same entity. when i use cooper and then select these two faces as the source faces, there produced negtive volume. i checked the grids and although the source faces are regular paved grids, as shown in the bottom picture, the grids inside is rather weird. as to the right scheme, it seems only a hex cooper and a hex/wedge cooper are available. i can't figure out where the problem lies.Could you be so kind to tell me?
Old   May 31, 2011, 07:46
-mAx-'s Avatar
Maxime Perelli
delete your mesh.
Mesh one cap of the volume with pave.
Go to volume mesh and select your volume
Gambit should select automatically cooper scheme.
Mesh the volume (it should also detect the right sources).
You can also enforce the source selection by clicking on top and bottom surfaces
Old   May 31, 2011, 08:17
J.G.Wang
delete your mesh.
I've tried lots of times just as what you showed me. but i don't konw why it could't be properly meshed. i didn't remesh any source faces as the cooper sheme requires.
I've been successfully meshed the entity(splited to many smaller entities) before with map tool, but you konw ,using map means the cells on the boundary is the biggest and the cells inside is smallest, it's not good to get a delicate boundary layer solution; so i have to use cooper.
Old   June 1, 2011, 01:31
-mAx-'s Avatar
Maxime Perelli
ok I assume this is a topology problem.
I could reproduce your weird situation.
If you delete the 2 inner cylinders, the problem has almost disappeared, but the 2 tangential volumes still don't accept cooper mesh.
I don't know why.
I did an 0.1mm extrusion for preventing high skewed elements in sharp corners, and then I applied a full hex mesh on those 2 volumes.
You can in crease quality in this area with a larger extrusion.
Anyway I would try to reconstruct your geometry for having something "clean"
Old   June 1, 2011, 02:06
J.G.Wang
I don't know why.
Attachment 7874
Thank you!you're so kind to help me so much!
i've followed what you told me in the last post to make a 0.1mm extrusion and managed to gain a good quality mesh for the 2 tangential volumes . As to the problem of cooper, if it really doesn't accept cooper mesh, i have to use tgrid scheme.
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
