How to make appear edge/line body (created in design modeler) in the meshing tool
Like Tree1Likes
  • 1 Post By Rockda
Old   June 6, 2011, 04:08
Default How to make appear edge/line body (created in design modeler) in the meshing tool
Rockda Kasba
Rockda is on a distinguished road
I would like to know how to make appear a line body in the meshing tool, after i created it in the Design modeler (2D) because for now i'm just able to see only the surface body i've created
To be more clear, i will illustrate this with a very basic example. Let's say i've created a rectangular surface and i draw a line in the middle of my piece ( which will be my nozzle exit when i'll use it in fluent). After created surface body from sketch (for the rectangular surface) and line body from sketch, when i switch to the meshing tool, my line body is not appearing in the tree view and i don't know why..so i will not be able to define a velocity inlet boundary conditions later in fluent..
Hope someone will be able to answer my question,thank you very much
Rockda
f.kh likes this.
Rockda is offline   Reply With Quote
Old   June 7, 2011, 10:01
Default Named Selections...
PSYMN's Avatar
Simon Pereira
This is not how you setup a 2D example in WB...
Instead, just use your surface body...
For the inlet or outlet, you don't need a separate line body, instead you just need a named selection for the edge of the surface body. This ensures that the boundary is properly associated, etc.
You can set the named selection up in the CAD tool, DM or ANSYS Meshing...
I made a demo/tutorial to show how...
http://www.youtube.com/ansysinc#p/u/14/-6Z2v8geroQ
Have fun.
CFD Online Users Survey
Old   June 21, 2011, 13:18
Default hi everyone
Olusogo fire
phire is on a distinguished road
I really need ur advice on this
I am try to model scour under pipelines lying on a seabed using FLUENT
I intend to use eulerian multiphase model which requires me to create two zones(water and soil).
I have used projection to split a surface into two under Design modeller to create the two faces.
The issue i have is that when i try to mesh the surrounding of the cylinder with ansys mesher; the mesh under the pipe is scattered because of the projection line that is there. how do i get around this
I have attached the picture of the mesh i got
pls i will appreciate any contribution
phire is offline   Reply With Quote
Old   October 3, 2014, 03:41
Default Wind Tunnel Problem
Thuy Nguyen
Thuy Nguyen is on a distinguished road
hello , i am making a research about wind tunnel. i use ansys fluent to check the sability fluid after through via a screem and honeycomb and i cant model them. im looking for many advices
Thuy Nguyen is offline   Reply With Quote
Old   May 19, 2016, 10:27
fahimeh
f.kh is on a distinguished road
Hi
I have the same question (as Rockda).
I wanna create an edge on one of my body surfaces to create better mesh.
I make the edge in design modeller, but it disappears from the body in meshing tool.
Thanks in advance for an early reply.
f.kh is offline   Reply With Quote
Old   June 8, 2016, 09:58
Henrique José
hcaribe is on a distinguished road
Hi Everybody. I have a similar problem and I will be gratefull if anybody helps me finding an answer. I am using ANSYS FLUENT in Student version. I am trying to do the best geometry in order to have a structured quadrilateral mesh in 2D. In this way, I made some lines around my foil and I am trying to make projections with these lines. But when I try to select these lines, ANSYS Design Modeler just donīt let me select the lines. I noticed that there are lines that can be selected, like the boundaries of the Domain, but I just canīt select the lines that I did for projections. Can anybody help me with an answer? Thank you very much!
hcaribe is offline   Reply With Quote
Old   June 8, 2016, 23:10
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
This thread is deprecated. Start a new thread and post some pictures. Thanks a lot
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Workbech design modeler geometry Faruk CFX 6 October 31, 2010 08:44
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 04:26
OpenFOAM with IBM AIX matthias OpenFOAM Installation 20 March 25, 2008 02:36
Design Modeler to ICEM..... Joe CFX 0 January 24, 2008 03:39
