January 17, 2013, 11:29 |
curve mesh bunching does not work?
Guan
Rep Power: 14 |
I am relatively new to ICEM 14.
I was trying the advanced bunching. But I cannot make it work. A test case was attached. I can see the effect of the bunching after I set the parameters. However, it seems the surface mesh does not use the curve mesh. |
January 17, 2013, 11:37 |
AB
Rep Power: 21 |
Patch independent is a surface based mesher.
Use patch dependent mesher if you want to specify the number of nodes on your curves. |
January 17, 2013, 12:23 |
Guan
Rep Power: 14 |
I do not want the mesh on the surface to be uniform.
I need finer mesh at one end and gradually grow to the other end. So I made a curve along the surface and mesh the curve with "advanced bunching" or bias under ansys meshing, but it does not apply to the surface mesh. |
Display Modes | |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 04:19 |
[ICEM] Hexa mesh, curve mesh setup, bunching law | Anorky | ANSYS Meshing & Geometry | 4 | November 12, 2014 01:27 |
engrid -> save as .stl with boundarie codes | Zymon | enGrid | 31 | August 29, 2011 14:40 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
basic of mesh refinement | arya | CFX | 4 | June 19, 2007 13:21 |
