rotational periodic boundary conditions in ICEM
How do I set rotationally periodic BCs in ICEM tetra?
I set Global Mesh Parameters>Periodicity>Rotational Periodicity, base (0 0 0), axis of rotation (0 0 1) z-plane, and angle 45. I have a 45 degree pi slice of a disk. Then I generated a tetra volume mesh automatically from ICEM. Then I set the BC of the periodic faces to periodic in the Output>Boundary Conditions. I output the mesh and read it into fluent, and get the error: Warning: Innapropriate zone type (periodic) for one-sided face zone, Changing to wall. The periodic faces are different parts. I tried setting the periodic faces to the same part but get the same error. Any suggestions? Thanks! |
Periodic mesh works just with Octree algorithm.
Use Octree to create (Lock) surf mesh for other volume algorithms. |
