rotational periodic boundary conditions in ICEM
Old   June 20, 2011, 16:22
Default rotational periodic boundary conditions in ICEM
user0314 is on a distinguished road
How do I set rotationally periodic BCs in ICEM tetra?
I set Global Mesh Parameters>Periodicity>Rotational Periodicity, base (0 0 0), axis of rotation (0 0 1) z-plane, and angle 45.
I have a 45 degree pi slice of a disk. Then I generated a tetra volume mesh automatically from ICEM.
Then I set the BC of the periodic faces to periodic in the Output>Boundary Conditions.
I output the mesh and read it into fluent, and get the error:
Warning: Innapropriate zone type (periodic) for one-sided face zone, Changing to wall.
The periodic faces are different parts. I tried setting the periodic faces to the same part but get the same error.
Any suggestions?
Thanks!
user0314 is offline   Reply With Quote
Old   June 21, 2011, 01:57
Ludvik is on a distinguished road
Periodic mesh works just with Octree algorithm.
Use Octree to create (Lock) surf mesh for other volume algorithms.
Ludvik is offline   Reply With Quote
Periodic boundary conditions happy5jump FLUENT 6 May 3, 2017 00:36
periodic boundary conditions fro pressure Salem Main CFD Forum 21 April 10, 2013 00:44
Rotational periodic Boundary condition achinta OpenFOAM 2 May 27, 2010 04:04
periodic boundary conditions mranji1 Main CFD Forum 4 August 24, 2009 23:45
periodic boundary conditions for species Muhammad Shakaib CFX 1 June 15, 2006 01:50
