Home > Forums > ANSYS Meshing & Geometry
[ICEM] Similar tetra refinement
Old   June 22, 2011, 10:37
Question Similar tetra refinement
Andreas P
andreasp is on a distinguished road
Hi all!
Somehow I can't believe I need to ask this because it seems trivial, but we are not getting the solution we want, so here's the question:
We have a 3D mesh consisting purely of tetra elements.
Now we want to refine this complete mesh with a similarity approach. That means, each tetra of the old mesh should be subdivided into 8 new ones, which are all similar to their "father". Thus, each edge should be split at its center into two new ones. The newly created nodes shall NOT be projected to the geometry surfaces. They should just stay at the same place where the former edge center used to be.
To me this really seems to be the simplest mesh refinement one could do. But how is it possible with ICEM???
Any help is appreciated!
Andreas
andreasp is offline   Reply With Quote
Old   June 22, 2011, 11:21
Andreas P
Maybe to shed a little more light on that issue:
We have tried the "Pure mesh refinement" method from the refine/coarsen menu. See the attached pngs for an example.
For the element marked in blue, the method seems to do what we want. At least the marked triangle is split into 4 as we desire.
However, the red element is refined awkwardly. Why? Do we have to explicitly tell ICEM to use the most simple dividing algorithm? If so, how can we do it?
Again, thanks in advance for any help!
Old   June 24, 2011, 12:35
Default Different way to get there...
PSYMN's Avatar
Simon Pereira
PSYMN will become famous soon enoughPSYMN will become famous soon enough
Under change mesh type, you could "add midside nodes". Turn off projection so they won't snap to surface.
Then "remove midside nodes" and use the option to convert to multiple linear elements...
It should give you exactly what you want.
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   June 27, 2011, 04:22
Andreas P
Perfect, that did the job!
Thanks!
Thread Tools
Trackbacks are On
Number of cells in mesh don't match with size of cellLevel colinB OpenFOAM Native Meshers: snappyHexMesh and Others 9 November 2, 2011 03:50
snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Native Meshers: snappyHexMesh and Others 2 March 27, 2011 21:11
snappyHexMesh aborting Tobi OpenFOAM Native Meshers: snappyHexMesh and Others 0 November 10, 2010 03:23
sMH refinement level subhkirti OpenFOAM Native Meshers: snappyHexMesh and Others 0 October 13, 2010 04:10
external flow with snappyHexMesh chelvistero OpenFOAM 11 January 15, 2010 19:43
