-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   STL to hex mesh (http://www.cfd-online.com/Forums/ansys-meshing/89956-stl-hex-mesh.html)
theMBV June 27, 2011 10:06
STL to hex mesh
Hi guys,
I have an STL file and I need to turn it into a hex mesh in ICEM. Is there a way to derive a CAD/workable part from an STL file that you can't get any measurements from? Im trying to create a hex mesh using blocking.
Thanks
dizzy June 27, 2011 12:13
This might be helpful:
http://www.cfd-online.com/Forums/ans...face-icem.html
http://www.cfd-online.com/Forums/ans...ic-domain.html
PSYMN June 28, 2011 12:56
No problem.
The Hexa blocking tools work perfectly fine from faceted geometry (such as STL).
It does help to extract feature curves (Using build topology).
I don't think there are any tutorials that cover this directly (STL -> Hexa), but if you try one of the STL to Tetra tutorials it will give you all the right prep information to get going with ICEM CFD Hexa.
I didn't understand what you mean when you say you can't get measurements from your STL file...
One extra feature... Once you have a Hexa blocking of an STL part, you can actually convert the surface of the blocking into nice bspline geometry (since it has well defined i-j space for each face) so you can export an IGES file. This is done under the edit menu.
Omarspace March 26, 2015 05:01
stl->Hex
When I try to mesh stl file into hexa , it meshes only surfaces not the volume where is the step that i may missed ?
thanks
CFDUser_ May 9, 2016 03:18
thanks
Hello Omer,
Did you find the bug? I am facing similar issue.
Thanks & Regards,
CFDUser_
