[ICEM] Negative Volume Help
Old   June 29, 2011, 16:23
Default Negative Volume Help
KJ Lee
leekj92 is on a distinguished road
Hi everyone, I'm meshing a pipe with fittings, with the main pipe having another pipe going through. I just need a little bit of help on how i should move the vertices to fix my negative volume problem. Tried the ICEM smoothing functions which created overlapping/penetrating elements. I think this should be simple fix but I do not know which vertex to move.
Attached are the pictures!
leekj92 is offline   Reply With Quote
Old   July 1, 2011, 04:32
Ludvik is on a distinguished road
These slim elements on below of elbow are too long relatively to curvature.
Increase the number of elements or try to use as "Edit Edge > Link Edges", "Edit Edge > Split type".
Ludvik is offline   Reply With Quote
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
