[ICEM] Plot3D mesh import problem
Like Tree1Likes
  • 1 Post By drbones
Old   January 26, 2012, 11:53
Default Plot3D mesh import problem
Bromby
drbones is on a distinguished road
I had been using ICEM 13 to import a multiblock PLOT3D file. My university updated to ICEM 14.0 and now I can no longer import the files.
The log window does not spit out any red text errors, but does say this:
Running ICEM CFD/CAE PLOT3D Input Interface Vers. 14.0.0
Plot3D file contains 2 block(s)
Nodal dimension of block(s):
- Block #1: 147 x 12 x 1
- Block #2: 151 x 13 x 1
Skipping block #1 with iblank value 0
Skipping block #2 with iblank value 0
I get the same message whether or not I toggle the iblank option on/off in the plot3d option menu (or if I select the 'take a guess' option). And needless to say, the workspace remains void of any mesh.
I also cannot find the format for how to include iblank values in the original file (should be =1 I believe). But I would prefer to forgo iblanking all together because it's not a necessary feature for what I'm trying to do.
Thanks for any help you can provide!!
drbones is offline   Reply With Quote
Old   January 27, 2012, 15:18
Bromby
OK, so I have contacted ANSYS through their 'Academic Tech Support'. They were able to recreate the problem, and said it appears to be a bug.
The following was their response:
"It seems that V 14 cannot handle iblank arrys - seems to be a bug that has resurfaced. I tried various workarounds without success. Unfortunately, until this is fixed, your best bet is to revert to the older version of the translator. To fix, replace the file (pl3d2domain.exe) in C:\Program Files\ANSYS Inc\v140\icemcfd\win64_amd\icemcfd\output-interfaces
I have attached a zip of the replacement file they sent me.
swm likes this.
iblank, icem, multiblock, plot3d
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
[ICEM] Problem making structural mesh on a surface froztbear ANSYS Meshing & Geometry 1 November 10, 2011 08:52
[Gmsh] gmshToFoam problem: not the same mesh in Gmsh vs. paraview zhernadi OpenFOAM Meshing & Mesh Conversion 8 July 7, 2011 02:28
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
