[Other] Setting up time steps for transient thermal analysis on mechanical
Old   July 18, 2013, 04:29
Smile Setting up time steps for transient thermal analysis on mechanical
TD07 is on a distinguished road
Good morning dear community,
I am trying to model a transient heat transfert problem ; a pipe, containing some water at 20°C (initially) is heated with a wire fixed on its side. Around the pipe and the wire, i put a layer of insulating material. I want to run a simulation that would last for at least 3 hours to see how fast the fluid is getting heated up. However, it seems that mechanical does not allow me to set a time step greater than 1, which means i have to run 10800 iterations (1 for each second).
Also, i ve tried to get around this problem by reducing the number of -sub-increment which is set to 100 by step (defaut value) to 1, but i have to specify it manually for all the 10800 steps, which is a waste of time.
Can anyone here please tell me how to increase the time step beyond 1s or tell me how to change the number of sub-increment for all steps at the same time ?
Thank you
TD07 is offline   Reply With Quote
increment, step, thermal, time, transient
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 13:40
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
Warning 097- AB Siemens 6 November 15, 2004 04:41
