Home > Forums > ANSYS Meshing & Geometry
[ANSYS Meshing] Blocking of a static mixer
Old   July 6, 2011, 03:20
Default Blocking of a static mixer
donkey86 is on a distinguished road
Hi there,
I have a question regarding the blocking of a static mixer. In the pipe I have 9 mixing elements protruding to the inside. Now I have no idea how to block this parts.
Using the Manual, I figured out to put blocks around these elements, but I am not sure about the collapsing tool and how to use it. May you guys have some good ideas or advices on how to procede.
Thank you very much for the help!
donkey86 is offline   Reply With Quote
Thread Tools
Trackbacks are On
error: uninitialized local variable 't' used MASOUD Fluent UDF and Scheme Programming 3 November 26, 2012 06:24
fprint problem MASOUD Fluent UDF and Scheme Programming 5 October 30, 2011 17:08
defining a term for a domain using DEFINE_ADJUST MASOUD Fluent UDF and Scheme Programming 1 September 24, 2010 05:08
enum MASOUD Fluent UDF and Scheme Programming 0 June 5, 2010 00:49
Simulating a static mixer in Fluent Novice FLUENT 1 January 26, 2009 14:09
