Problem With Importing Coordinates for an Airfoil
Like Tree1Likes
  • 1 Post By Mazze[ITA]
Old   October 22, 2010, 12:12
Default Problem With Importing Coordinates for an Airfoil
Amerikaneca is on a distinguished road
Hello everyone,
I have a .dat file with the coordinate points for a NACA4412 airfoil. I want to build the geometry, mesh it and analyze it with Fluent. However my first issue is that I cannot import the 500 or so coordinate points into Workbench Design Modeler. I keep looking online and I cannot find a direct answer to my question. Is it possible to import a .dat file into the DesignModeler so I can create the airfoil geometry? Short of that what do I need to do to import the coordinate points into the client? Can you give me any advice please? Thank you.
P.S. I figured it out, turns out it is quite easy. Select Point, Coordinate File, and make sure the coordinates are in a .txt file following the format:
Group Number Id Number X coord. Y coord. Z coord.
1 1 1 2 3
1 2 2 3 4
1 3 2 1 4
etc...
The help feature actually did help this time.
Amerikaneca is offline   Reply With Quote
Old   December 7, 2010, 07:33
Alex
coondason is on a distinguished road
What does Group Number and Id number mean? in terms of design modeler that is
thank you
coondason is offline   Reply With Quote
Old   January 5, 2011, 14:21
Lorenzo Mazzei
Mazze[ITA] is on a distinguished road
A little advice. I've understood DM demands the comma, not the dot in the .txt list.
Centurion2011 likes this.
Mazze[ITA] is offline   Reply With Quote
Old   July 8, 2011, 07:28
Centurion2011's Avatar
Centurion2011 will become famous soon enough
this is correct answer:
http://www.cfd-online.com/Forums/cfx...ler-ansys.html
In Ansys 12.1 I go to Concept menu and then select 3D curve. I then Import coordinates from .dat file in format mentioned in upper link
Centurion2011 is offline   Reply With Quote
FFA-W3-211 airfoil geometry coordinates chelvistero OpenFOAM 12 June 24, 2018 15:38
[Commercial meshers] Handling cyclic BC from gambit to openfoam for a cascade airfoil problem - OF 1.6 maverick OpenFOAM Meshing & Mesh Conversion 2 June 18, 2011 04:36
Calculating polars from 2D airfoil coordinates... wlvrn Main CFD Forum 0 August 18, 2010 18:43
Problem importing solidworks to gambit holyo ANSYS Meshing & Geometry 3 April 16, 2010 05:16
flow simulation across a small fan jane luo Main CFD Forum 15 April 12, 2004 17:49
