[ICEM] Quest for seemingly simple Blocking (degenerate block) |
July 12, 2011, 19:48 |
Rep Power: 15 |
Dear All,
is it possible to create a block to cover a box with two corners merged (resulting in a seven cornered "box")? The 1st attached picture will make my question clear. Whenever I merge two corner vertices of a block with a swept face or free block, a face will be missing as seen on the first picture. If someone could put a block in there with the upper and lower face set free (unstructured) do not hesitate to share the result with me (I attached the .tin and .blk files in a zip)! I would like to stitch that block to an existing blocking of mine...Thanks for any help in advance! The best I could make is to put a wedge on top of the existing degenerate block (2nd pic) then convert the wedge to a Y-block. But as the lower, degenerate block didn't have an upper face the resulting mesh is penetrating (see the 2nd pic). |
[ICEM] Blocking and Symmetry | BrolY | ANSYS Meshing & Geometry | 32 | August 24, 2012 03:13 |
[ICEM] Simple Meshing (w/o blocking) | shohin | ANSYS Meshing & Geometry | 7 | May 25, 2010 04:23 |
Can Fluent handle a degenerate block? Error while reading mesh... | Anorky | FLUENT | 1 | May 1, 2010 12:47 |
[Commercial meshers] Icem Mesh to Foam | jphandrigan | OpenFOAM Meshing & Mesh Conversion | 4 | March 9, 2010 02:58 |
Block correction scheme in SIMPLE | Chuck Leakeas | Main CFD Forum | 0 | November 20, 1998 12:51 |
