July 14, 2011, 13:22 |
Can I create hanging nodes in ICEM?
KJ Lee
If so, could anyone give me a quick guideline? Thanks! |
April 8, 2013, 00:52 |
Is there really no way to directly introduce hanging nodes in ICEM?
Carlo
Why hasn't this issue been addressed? I see this thread is 2 years old.
April 8, 2013, 03:13 |
Astio Lamar
Sure!
Blocking => Pre-mesh Parameters => Refinement |
April 8, 2013, 04:01 |
Hanging nodes - how do I 'unlink' adjacent blocks?
Carlo
Hi asal, thank you for your response. I looked at this but I couldn't make it work. There is probably something I miss. I'm not in my office right now, but I will try this first thing tomorrow. If I refine a block, will that unlink the bunching of its edges from the adjacent blocks? If I have one block and I split one edge I get two blocks. If both blocks are 'mapped', how do I refine one without touching the resolution of the other? Thanks for your help! |
April 8, 2013, 05:14 |
Astio Lamar
Well,
If you have block and cut it out in to two blocks, then you can select one and refine it in all or one edge. Then based on your solver, you shoud decide to merge the nodes in the common adge. If you want to run over fluent, then this software don't care about the double refinment, but for triple refinement, you have to merge the nodes at after converting to mesh. |
April 8, 2013, 19:21 |
Making progress..
#7 | |
Carlo
So far I've managed to introduce the hanging nodes but I think I need to merge the meshes, right? I have blocks of hexa elements and it seems that the only way to merge them is with pyramids (I read this in the help). Should I split the vertices on the common edge? Can I have some help on how to proceed after the refinement? Thanks guys |
April 9, 2013, 01:02 |
found the problem.. but still not there..
Carlo
Hi folks - so I managed to make things work by splitting the main block into (say) three parts, refining one block then rebuilding the mesh topology. This last step recreated some nodes that allow my solver to understand the connectivity. However, the faces in between blocks are now recognized as "parts", i.e. physical boundaries. Any ideas? It tells me that Fluent does not want uncovered faces, but how can I cover these intra-block faces without having my solver (which I think behaves exactly like Fluent) think they are boundaries?
Last edited by cscalo; April 9, 2013 at 01:35. Reason: (typo and extra information) |
hanging nodes in fluent; | Zafer Zeren | FLUENT | 6 | April 9, 2013 14:25 |
[blockMesh] Include list of points | Hikachu | OpenFOAM Meshing & Mesh Conversion | 0 | June 20, 2011 09:03 |
Create STL from ICEM CFD? | Michael B | CFX | 0 | November 2, 2006 08:35 |
How many nodes to create a mesh?? | Vidya Raja | FLUENT | 1 | May 27, 2006 14:12 |
Creating hanging node in ICEM CFD | korcan | FLUENT | 0 | May 15, 2006 10:37 |
