March 5, 2012, 11:18 |
Specifiy boundary type
Robins A G
Rep Power: 14 |
Hi, I made a model of a centrifugal pump, but what boundary types do i have to specify for the pump? So what should i do?
March 5, 2012, 11:28 |
post few pics. Generally boundary conditions are
1. Inlet : Pressure inlet >>>>>>> specify total pressure and flow angles. 2. Outlet : Pressure Out >>>>>> Specify the static pressure required to produce the mass flow rate. 3. Blade and hub: no slip condition wall 4. Casing . Zero Velocity in absolute reference frame. 5. Periodic boundary : If modeled one or two passages. |
March 5, 2012, 12:07 |
Impeller speed
Robins A G
Rep Power: 14 |
The impeller speed is 1300 rpm, how it specifiy?
March 5, 2012, 12:38 |
Robins A G
Rep Power: 14 |
Okay, thank you for the answer.
Need help with boundary conditions: open to atmosphere | Wolle | OpenFOAM | 2 | April 11, 2011 07:32 |
Pressure instability with rhoSimpleFoam | daniel_mills | OpenFOAM Running, Solving & CFD | 44 | February 17, 2011 17:08 |
Boundary condition setting for non-premixed combustion using reactingFoam | skyopener | OpenFOAM | 0 | May 23, 2010 22:55 |
pipe flow with heat transfer | Fabian | OpenFOAM | 2 | December 12, 2009 04:53 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
