-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   Can't import geometry file from Icem CFD to Ansys Workbench (http://www.cfd-online.com/Forums/ansys-meshing/90723-cant-import-geometry-file-icem-cfd-ansys-workbench.html)
Julien87 July 19, 2011 10:30
1 Attachment(s)
Hi everybody,
I created a geometry file with Solid Edge ST2 (*.par then via import geometry) to adapt it in Icem CFD 12.1.
Then I tried to load the adapted geometry file with Ansys Workbench 12.1 but it was not possible.
I attached the error message of Ansys below. (German version)
Thanks for helpfull answers,
Julien
Andrew.Coughtrie July 19, 2011 16:50
The easiest way to import a geometry into workbench would be to save/export the file as a parasolid file in ICEM so an x_t or x_b file as the workbench geometry modeller has a parasolid kernel and handles parasolid files better than any others such as IGES and SAT. So if you want to import a geometry to workbench thatís what I suggest.
Hope it helps
Andy
