July 13, 2011, 14:59 |
Meshing on a Complicated Geometry
Timothy
Rep Power: 16 |
I need to make a good mesh on a very complicated geometry (see pictures). I plan on running an LES simulation on a model of the human upper airways (lungs). in the form of an STL I have used Materialize software to extract a geometry from CT scans . I have access to ICEM and I wanted to ask where to begin on a model like this? My thoughts were to use a tetrahedral mesh because of complexity. It would be great if I could use hexahedral and still get good quality elements because of the reduction in computational time. I think it would be good to use prism layers at the surface but I am not sure if that would cause a problem with LES. Either way it is important to have very small elements near the wall. I do not have a lot of experience with meshing and I wanted to know if anyone had any thoughts or suggestions for me. What kind of meshing strategy would you use for a geometry like this?
Thank you for your time, Timothy |
August 17, 2011, 11:09 |
Timothy
Rep Power: 16 |
Simon has suggested a method of blocking for this geometry that I have tried with some results.
I have started with a bounding block. I split the block in half from top to bottom at the first split in my geometry. Then, because the splits in my geometry were not very sharp, I split the lower block into three blocks and deleted the middle block. I moved the nodes of the blocks so that the two lower blocks aligned with the two split directions. I would then perform a similar procedure on the next split on each side of the first split. I continued this process associating as much as possible along the way until my entire geometry was blocked. |
August 17, 2011, 11:15 |
Next Challenge
Timothy
Rep Power: 16 |
The result looked pretty cool but has some overlapping elements. (see picture)
Below is my blocking structure in that region. Does anyone know why I may be getting overlapping mesh here? I do not know what the problem is so I do not know the information one would need to figure out what is wrong. If you need any more pictures or information let me know. Thanks, Timothy |
[ANSYS Meshing] TurboGrid export geometry after meshing | la7low | ANSYS Meshing & Geometry | 0 | January 13, 2011 19:50 |
Complex Geometry Meshing | andreasp | Main CFD Forum | 2 | September 26, 2010 15:16 |
Please help in meshing this complicated geometry | eers | Main CFD Forum | 7 | July 8, 2009 20:42 |
vitual _ real | deneb | FLUENT | 3 | January 22, 2007 04:31 |
Geometry and meshing with CFX | Bob Crad | CFX | 3 | January 7, 2004 12:56 |
