meshing an outer volume to meet inner meshed volume
Old   August 17, 2011, 20:40
Default meshing an outer volume to meet inner meshed volume
Damien
dameyawn is on a distinguished road
Here is a screenshot for a basic case of what I want to do.
http://imgur.com/ZpAvK
Essentially, I'd like to mesh the inner volume at a fine mesh to capture certain physics. Then, as you can see, I've applied boundary layers to the faces of the outer volume, but because that volume contains a void, I can't map mesh it.
I'd like to mesh the outer volume in such a way that it meets the finer resolution of the inner volume. I also need to keep the mesh orthogonal.
Any ideas or help would be appreciated.
dameyawn is offline   Reply With Quote
Old   August 18, 2011, 00:24
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
split outer volume with inner volume
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
boundary layer mesh, volume meshing
[GAMBIT] error meshing volume on sedan geometry AbdulAzis ANSYS Meshing & Geometry 20 October 13, 2015 02:16
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
'Tetrahedral meshing has failed for volume...' Murat FLUENT 5 February 19, 2011 04:22
Workbench volume meshing skaboy607 ANSYS Meshing & Geometry 19 February 12, 2011 18:15
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
